Vacuum Leak Advice
Old Apr 1, 2015 | 09:36 AM
cromeo68's Avatar
cromeo68
Question Vacuum Leak Help Needed
I just changed the oil pan gasket with help from a previous post, and successfully I may add. TY again for those that helped. However I have a new issue:
The vacuum lines from the vacuum shift motor were brittle from age and I inadvertantly hit them with a ratchet and broke them I have replaced the lines, now my truck wont idle at all, it runs smooth while moving but soon as the rpms drop at a stop sign it dies immediately, I have looked for other lines loose or broke to no avail. my question is, are there any key areas I can look at for a leak that would cause this? ie are there other lines under the engine that I am not seeing or would there be a hose around the carb, I did take the air filter housing off to lift the engine, I did not do any other work on it, and it ran perfect before.
Last edited by cromeo68; Apr 1, 2015 at 10:30 AM. Reason: Needed more useful title
Old Apr 1, 2015 | 11:28 AM
cromeo68's Avatar
cromeo68
Also wanted to mention that when its a low rpms it runs rougher than normal driving rpms.
Old Apr 1, 2015 | 02:32 PM
UnregisteredUser's Avatar
UnregisteredUser
Take a look on the passenger side of the engine in the area between the midpoint of the intake manifold and the cowl. There are a couple of lines there that are easily enough broken when futzing around with the air cleaner.
Old Apr 1, 2015 | 10:38 PM
2damnyankee's Avatar
2damnyankee
Check the 4wd line running down the top of trans going back to the transfer case, that line is brittle and always breaks
Old Apr 2, 2015 | 10:44 AM
cromeo68's Avatar
cromeo68
I will look at those things, TY for your feedback
