Old Aug 10, 2015, 07:01 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Tire Repair and Maintenance
Print Wikipost
hub bearings on front passenger wheel
Old Apr 3, 2015 | 11:37 PM
Katelyn m's Avatar
Katelyn m
Default hub bearings on front passenger wheel
My boyfriend just replaced his front hub bearing 4 weeks ago and it is already completely out again. What could be causing this he has a dodge ram 1500 4x4
Old Apr 4, 2015 | 01:44 AM
AtomicDog's Avatar
AtomicDog
Few things to check for - defective replacement hub bearing, incorrect torque applied to retaining nut, U-joint behind the hub bearing bad and binding up.
Old Apr 4, 2015 | 08:21 AM
2damnyankee's Avatar
2damnyankee
What kind of tires and wheels are you running ? are the ball joints and tie-rod ends good? Have you had a wheel alignment lately? Did you torque the axle nut properly . Did you make sure that the bearing was seated completely flush? all these things can and will lead to premature bearing where in the hub.
