variable RPMs
Old Oct 30, 2005 | 12:31 PM
stewvu's Avatar
stewvu
Default variable RPMs
I have a 2001 Ram 360. When I get between 60 and 65 mph the RPMs jump around about 200 -300 rpms. I have replaced the TPS but nothing changed. Has anyone else had this trouble and know what I should try next?
Old Oct 30, 2005 | 12:48 PM
steve05ram360's Avatar
steve05ram360
Default RE: variable RPMs
your TPS sensor is noisey causing your torque converter to lock and un-lock. get a new one and you'll be good to go.
Old Oct 30, 2005 | 04:56 PM
Racinfan83's Avatar
Racinfan83
Did you reset the computer after replacing the TPS? If not - try that. I assume the TPS replacement was recent.......
Old Oct 31, 2005 | 12:17 AM
Dlinzy's Avatar
Dlinzy
My 99 does this, surges around 2200 - 2400 back and forth while i remain steady with the throttle. Almost seems like a fuel issue.... a lil gas, no gas, a lil gas no gas
And what's a TPS ? where is it and how do i replace it?
Also have a tranny leak and looking at possibly replacing the tranny ???
99 360 4x4 with 130K 4" lift 35" bfg at's
denny
Old Oct 31, 2005 | 12:54 AM
steve05ram360
ORIGINAL: steve00ram360
ok, check that... day light savings time... that's my excuse and i'm sticking to it...! it could be your lockup solenoid is going bad. 99% of the time though it's the TPS.
Old Oct 31, 2005 | 01:36 AM
Dlinzy's Avatar
Dlinzy
Thanks for the quick response.
Where would i go to get a TPS for a 99 360 4x4?
Part # ?
TIA,
Denny
Old Oct 31, 2005 | 11:10 AM
jrmcx's Avatar
jrmcx
Just head to any car parts store and ask for a Thottle Position Sensor. It's a popular item.
