How do the sockets look? Are the tabs corroded and or bent so they don't make contact. Does the sleeve (insulation) of the wire look brittle and cracked?
Grab a factory service manual from the FAQ/DIY section of this forum, and do some troubleshooting. That's the answer to the question I assume you would have asked if you'd gotten around to it.
