sway bar end links binding?
Old Apr 29, 2015 | 08:11 AM
BrandonBuc'em's Avatar
BrandonBuc'em
Track bar is not original. It may be one though.
I think you're on to something with the drop brackets or the links need to switched around.
Question : are longer end links from say suspension maxx ment to be used with drop brackets or the way it mounts up stock?
Also I'll post pictures in a couple hours on my break. I can tell you axel is centered under the truck. I'll show you though.
Old Apr 29, 2015 | 08:12 AM
BrandonBuc'em
Track bar is not original. It may be oem though.
Old Apr 29, 2015 | 09:22 AM
Wh1t3NuKle's Avatar
Wh1t3NuKle
I looked at the instructions. You've got the drop brackets correct from what I can tell. However, there is no elaboration on the rest of the bolting up. Based on the instructions, you wouldn't have had to mess with the links as it only calls out to unbolt from the frame. Then add the brackets and reattach.
This thread may help.
https://dodgeforum.com/forum/2nd-gen...with-lift.html
Old Apr 29, 2015 | 09:41 AM
BrandonBuc'em
Thank you for sharing that, very helpful
