Security system disable
Old May 19, 2015 | 12:27 PM
rebelrufus's Avatar
rebelrufus
Default Security system disable
I've searched around for this issue and haven't found much.....
I desperately want to disable my alarm / security system on my '01 Dodge Ram 1500. I pulled the security relay under the hood a few months ago, but I still get an alarm sometimes when unlocking the truck with the key or the fob?? Usually when I press the unlock on the FOB or open the door.
I just want the dam thing out! Read something about cutting a wire on the CTM? But not a whole lot of info to go on to just start snipping wires.
Oh yeah, it is the factory alarm system, not aftermarket.
Thanks for any help.
RR
Old May 19, 2015 | 04:24 PM
TNtech's Avatar
TNtech
Site Moderator-Dodge Tech
A dealer or someone with a DRB 3 can go into the central timer module and disable "VTSS".
One thing you may run into down the road though. Many times if a PCM is without power, it can wake up in an armed state and cause a no-start. Then you will have to get it Enabled again.
