Strange squealing noise?
Old May 26, 2015 | 05:05 PM
Jeff_S's Avatar
Jeff_S
Default Strange squealing noise?
So I've just finished installing the Hughes plenum kit with the aluminum 1/4" plate and whatnot, and the truck is running great! Though as one item is fixed, another arises...
Now there's this weird squeaky/whining noise coming from the front end of the truck. I don't think its the serpentine because the noise only occurs when the wheels are moving, not if I rev it in neutral. I think it may be a steering pump problem as it is more prevalent if I am turning right than left, but the whine usually coincides with the speed of the tires, so I'm kinda stumped.
Anyone have a sound similar to this? Its obnoxiously loud, kind of a squeaking.
Thanks for any help!
Old May 26, 2015 | 09:17 PM
Wildman4x4nut's Avatar
Wildman4x4nut
Veteran: Army
Check your brake pads first as they have a low pad warning device so that maybe what you are now hearing.
Old May 27, 2015 | 11:39 AM
Moparite's Avatar
Moparite
X2! That's why they are called "squealers". Small metal tabs that hit the rotor when the pad gets worn.
Old May 27, 2015 | 12:17 PM
hemiquad4x4's Avatar
hemiquad4x4
Jack the front end up and turn the wheels and listen for any noise?
Old May 27, 2015 | 08:37 PM
ReadRam's Avatar
ReadRam
Wheel bearing? Sometimes they moan and sometimes they squeal.
