One piece axle shaft
Old May 26, 2015 | 09:23 PM
Deadlymopar408's Avatar
Deadlymopar408
Default One piece axle shaft
I have a 94 Ram 1500 and im curious if their is a company or something to eliminate the 2 half shaft on the front passenger side so its a solid one piece?
Old May 26, 2015 | 10:23 PM
armynurse's Avatar
armynurse
EMS sells a one-piece axle.
I used an item called a "perm-lok" to permanently slide the collar over (google it). It's a lot cheaper and a lot less labor intensive to go this route vs. the solid axle. Once installed you can pull all your vacuum lines (and cap the one vacuum port).
Old May 26, 2015 | 10:33 PM
armynurse's Avatar
armynurse
Check this out - it goes into more detail with part numbers and such:
https://dodgeforum.com/forum/2nd-gen...ml#post3162798
Old May 27, 2015 | 10:56 PM
Deadlymopar408
I'm trying eliminate the whole folk engage four wheel deal the vacuum system is plugged and i have already welding the metal sleeve to inner shaft, and I was trying to find a one shaft to make my life easier.
Old May 28, 2015 | 06:51 AM
Spillage's Avatar
Spillage
Something like this?
http://www.emsoffroad.com/store/inde...ex&cPath=65_68
