Engine wont start
Old Jun 24, 2015 | 10:33 AM
Moparite's Avatar
Moparite
You need to see if you have positive (+ 12 volt) to one lead on the coil with the key on. That is the first step the second is if you are getting a trigger signal(- negative) from the pcm(this is the other lead on the coil when cranking the engine). Pull both wires off the coil when you test this!
