46re transmission
Old Jul 11, 2015 | 07:23 PM
eagle101's Avatar
eagle101
Default 46re transmission
I am having a problem with the transmission staying in limp mode. I was advised that it sounded like a wiring problem, a wire shorted to ground etcetera. I checked the wiring with the battery disconnected and the governor pressure sensor pins 1&3 or 2&4 I don't know which are which, but they are shorted to ground when the PCM is connected. Is this the proper readings. The trouble codes are p0711 p0713 and p1763.
Old Jul 12, 2015 | 12:33 AM
JoshuaYsassi's Avatar
JoshuaYsassi
I Don't know what the codes are but I overhauled my whole transmission on my 95 Dodge ram 1500 5.9l 4x4 mine did the same we figure out we caught the sensor wire that runs out the top between the Trans and engine which we had to put a new one and and ran great till now haha but hope this helps goodluck
Old Jul 12, 2015 | 10:43 AM
Moparite's Avatar
Moparite
P0711 Trans Temp Sensor, No Temp Rise After Start
P0713 Trans Temp Sensor Voltage Too High
P1763 Governor Pressure Sensor Volts Too High
Check the wiring/pin connections with the wiring diagram in the service manual.
