transmission fluid
Old Jul 16, 2015 | 02:38 PM
eagle101's Avatar
eagle101
Default transmission fluid
I have a2001 ram 1500 with a46re transmission. I changed the transmission fluid and filter and put in 4 qts of fluid. The manual says 4qts but it is not even touching the dip stick. Does anyone know how much fluid it takes.
Old Jul 16, 2015 | 03:09 PM
How are you checking the level? Engine warm? Level ground? Trans in neutral? IIRC, about 6 quarts comes out when dropping the pan.
Old Jul 16, 2015 | 03:22 PM
eagle101's Avatar
eagle101
Yes I checked it properly. I p u t 4qts in because that what the manual said. Thanks for the info .
Old Jul 16, 2015 | 03:31 PM
If you are checking like your supposed to, just start adding more and checking it every so often till it reaches the correct spot on the dipstick.
Old Jul 17, 2015 | 11:07 AM
jmhd1989's Avatar
jmhd1989
4 qts is what the manual says because it is a safe starting point. they knew more than 4 would come out but by starting you at 4 qts they remove risk of over filling. start at 4 and go from there. it also depends how long you let it drain. i drained mine for over a week while servicing seals and transfer case and got 13 qts out.
