Horn Replacement -w- fuses.
Old Sep 30, 2015 | 05:31 PM
PaulMcKIII's Avatar
PaulMcKIII
Default Horn Replacement -w- fuses.
I'm trying to replace my horn with a non stock style. However the horn that I choose requires a 30 amp fuse and the stock horn only requires a 20. Is it possible to replace that 20 amp fuse for the horn with a 30.?
Old Sep 30, 2015 | 05:35 PM
It is possible, but the wiring is probably designed for 20 amps max. So you "could" run the possibility of melting some wires.
Old Sep 30, 2015 | 08:08 PM
PaulMcKIII's Avatar
PaulMcKIII
Is there a way to avoid that.
Old Sep 30, 2015 | 09:49 PM
Yes. Run new wires rated for 30 amps.
