high idle low idle
Old Nov 18, 2015 | 07:43 PM
bunker's Avatar
bunker
Default arrggg
Pull the relay, stick one probe from your meter in the ground side of the relay control circuit, and the other probe to a good ground. See if there is continuity. (or zero resistance, if your meter doesn't do continuity testing.)
will do when the rain goes away raining like crazy here. thanks will get back to you
