Won't run. Intake drenched in oil.
Old Jan 14, 2016 | 07:49 PM
fetters_27's Avatar
fetters_27
Default Won't run. Intake drenched in oil.
i have a 98 dodge 2500 with a 360 it only has 160,000 miles and i was plowing snow yesterday(ohio) and the truck started running really ruff wouldn't rev up and then shut off and wouldnt start again.....
so i took the spark plugs out and they are all drenched in oil and the inside of the intake is coated in oil. I did a compression test and have 120-125lbs in each cylinder... i put new plugs in and i have good spark but the truck won't start
HELP!!! PLEASE
Old Jan 14, 2016 | 08:13 PM
Warlock_III's Avatar
Warlock_III
The obvious issue is you most-likely need to do the plenum. It should still start and run though.
Have you attempted to check fuel pressure or tried pouring a little bit of fuel down the throttle-body? If you have a helper have them either turn the key to start it and at the same time hit the fuel tank moderately with a rubber mallet, dead-blow hammer, or the toe of your boot.
I can appreciate needing help, however; in the future try to put a legitimate subject matter in the title. This helps future members search the forum (search function) in an attempt to resolve their issue as quickly as possible.
(Edit: Nice move changing the title)
Old Jan 14, 2016 | 09:17 PM
Plenum is blown. Converter is probably clogged. Fixed the title. Time to read up on the plenum fix.
Old Jan 15, 2016 | 12:11 PM
Moparite's Avatar
Moparite
http://www.hughesengines.com/Index/p...p?partid=27091
Old Jan 15, 2016 | 03:30 PM
dapepper9's Avatar
dapepper9
Originally Posted by Moparite
Fixed.
Start with simple felpro or mopar gasket and pcv valve change and go from there. Run some combustion cleaner through and check compression again.
