Brakes
Old Jan 15, 2016 | 09:26 PM
Dodgerblue0314's Avatar
Dodgerblue0314
Default Brakes
I put new calipers on today and I can't get the brake lines completely bled. It's on a 2000 1500 with only rear wheel ABS and after I did it my parking brake light come on and my ABS light come on. Is there a trick to bleeding these lines?
Old Jan 15, 2016 | 10:17 PM
UnregisteredUser's Avatar
UnregisteredUser
Nope, no trick to it. It's just a PITA to get a thorough bleed after replacing calipers.
It's faster and easier if you've got a power bleeder, which gets rid of the helper and the tendency for air to sneak back in before you get the bleeder closed.
Old Jan 15, 2016 | 10:30 PM
dbbd1's Avatar
dbbd1
By power bleeder, do you mean the vacuum type or the pressure type?
Old Jan 16, 2016 | 01:08 AM
UnregisteredUser
Personally, I use the Motive pressure bleeder that looks like a modified garden sprayer. I'm not a fan of vacuum bleeding.
