Just bought
Hey guys in just recently bought me a 95 dodge ram 1500, 5.9mag, in had two questions what's the best set of mufflers for a mean growl, the louder the better, 2cd I'm installing a 2in level kit do you think I could fit 285s?
Check out youtube for various videos of exhaust. That will give you an idea of what it will sound like.
285's may be tight with only two inches, but, should be doable. Welcome to DF! :D |
Welcome! Catch up on the maintenance before spending on mods.
Originally Posted by jkeaton
(Post 3281497)
Checked the plenum??
(Post 3281502)
Originally Posted by BroCody
(Post 3281490)
285 will work without the lift but to echo what the guys said PM the truck put your money where it needs it most before the fun parts
Originally Posted by evilemokid94
(Post 3281628)
never trust the older owner......when I bought mine the guy said he kept up on everything with it, it still had the original plugs, wires, cap and rotor on it, the radiator was leaking, and the trans went out less than 2 months later, transfer case chain was stretched and forks were bad, and the exhaust was messed up. Like the others said, do your maintenance lol
Well there was a oil leak into the intake manifold, and she was pulling hard to the right, thought it might have been tie rod, but it was the top and lower ball joint ,the thermostat was awful, ...but other than that all good |
So did you fix the plenum?
