Won't go into overdrive!?
Old Feb 23, 2016 | 09:54 PM
armynurse's Avatar
armynurse
There's a temperature outside where the truck won't go into overdrive. Doesn't mean anything is wrong with it. Happened to me once in Montana when it was below zero. I was freaking out - thought something major was wrong with my truck. Then I found out that was normal for these trucks.
Old Feb 24, 2016 | 08:18 AM
Moparite's Avatar
Moparite
Are you getting any trans codes?
X2!
Check for codes before you do anything!
http://dodgeram.info/Engine-Gas/OBDI/pcm_fault_code.htm
