Break dash warning light on
Old Mar 25, 2016 | 09:07 PM
byronpen's Avatar
byronpen
Default Break dash warning light on
Ive completed a brake job to to my dash light. Ive disconnected the battery over night. IdeaS?
Old Mar 26, 2016 | 12:13 AM
dbbd1's Avatar
dbbd1
Completely flushed the lines I presume?
IIRC there is done way to reset the abs. Here, I have compiled it from various posts.
ABS Light Reset
I finished a complete brake job on my 2001 Ram 1500 this weekend and couldn't get the ABS and brake light on the dash off no matter what I tried. The only thing that worked was to put a jumper in the OBD/DTC connector under the dash (where you plug in the data scanner). Confirm that you have a 16 pin connector and open up a small paper clip to make a jumper. Insert that into pin 4 (4th from the left on top) and pin 13 (4th from the right on the bottom) Turn the key on and pump the brakes rapidly 8-10 times. Turn off the key. The lights will be off. This only resets the lights so, if you have not corrected the underlying problem, the lights will come on again.
On the RWAL (Rear Wheel Anti Lock) module which sits 3" closer to the firewall than the proportioning valve, there is a rubber cap pointed horizontally right towards the master cylinder. Poke a paperclip thru the rubber cap about 1-1/2" until it touches the back of the RWAL accumulator piston. With key off, have a friend press and hold pressure on the brake pedal. If the piston moves, the service manual says to replace the RWAL. Mine moved, so the RWAL is supposedly bad. The only way for brake fluid to move the piston in the accumulator is for the anti-lock solenoid to be energized with battery voltage via the green wire on the "A" terminal of the connector... (OR if the solenoid valve is blocked open??, I thought.)
The leaking valve seat let fluid pass into the accumulator. The accumulator is spring loaded, so the "leak" doesn't go on the ground, rather it's collected in a spring loaded piston chamber and when you let off the brake pedal, the spring pushes the fluid back into the rear brake hydraulic lines & back into the master cylinder. Viola! Mushy pedal in spite of the following; brand new master cylinder, no air in system, fully bled system, NO visible fluid leaking under the truck.
My solution: My master cylinder reservoir was filthy with little black hunks of ??? in it. I suspected a chunk got caught under the solenoid valve seat during a hard stop yesterday, so with the key off/engine off I put 12volts to the green wire to energize the accumulator solenoid and repeatedly pressed the pedal to the floor and let it rest 10 seconds for a couple minutes. My theory was I could repeatedly fill and empty the spring loaded piston chamber of the accumulator and dislodge whatever might be blocking open the solenoid valve seat. SHAZAM! It worked...
If this problem comes back, I will do one of the following: Install a used RWAL module (new is big buck$) and powerflush all four corners again, or I will disconnect the rear brake lines from the RWAL module, connect them directly to one another, flush/bleed the system and effectively bypass the dang RWAL system.
If you end up with the proportioning valve shutting off the circuit you are working on, close all bleeders on that circuit, go to the OTHER end of the truck, have helper pump up the brakes, and HOLD it, then release one of the bleeders. This will get the p-valve to release again. Go back to what you were doing previously.
I checked all the soft lines and didn't find any leaks or kinks. However, I did have a new development today. Took the truck for a drive around the neighborhood and the brake pedal was behaving as normal. Then, suddenly, the pedal became mushy and went down to the floor while still stopping the truck. I messed with it some more and found that when I step on it hard, it has some resistance, but when I ease into it, it just sinks down. I did a little bit of research and read that this can be cause by a bad master cylinder seal. Then I read that the seals can fail if the brake fluid hasn't been changed in a while and then you attempt to bleed the brakes. Something having to do with buildup at the end of the cylinder that doesn't get used under normal circumstances, but can cause damage when the pedal is dropped to the floor during bleeding, which would make sense since I don't know when was the last time that the system was drained before I had it done a couple of days ago. This is all fine and good, but could this also be the cause of the lack of rear brakes? I'm thinking no since the the rear brakes seem to have failed BEFORE the fluid drain, but input is greatly appreciated.
Old Mar 26, 2016 | 08:10 AM
You completed a brake job to your dash light? What does that mean? More details would be helpful. Also reading what you wrote before posting will eliminate questions.
Old Mar 26, 2016 | 10:52 AM
Moparite's Avatar
Moparite
I didn't know you could do a brake job on a dash light.
Old Mar 26, 2016 | 11:01 AM
dbbd1's Avatar
dbbd1
Me? I can break anything.
