Solenoid? 46Re
Old Apr 2, 2016 | 03:09 AM
Double Oh Dodge's Avatar
Double Oh Dodge
Originally Posted by Jake95
It might be but im not sure, ive always wondered though cause the idle (in my opinion) is a little low at 750 in park. I know the first owner used her as fifth wheel hauler so maybe he got that converter set that way for a reason? All speculation until i get it taken apart and see what the heck they installed in it
Well considering what the coin phrase of Opinions says........ 750@ idle is a touch high if warm, and a touch low if cold.
Listed in sig Our family 2000 5.9 (assembled Oct 99) idles @ 900 cold start in ambient of 45° or lower.
Cold start in ambient of 60° and up, the idle is around 800 and up, No matter the ambient temp the operating temp (210 on dash using a 185° stat) idle is 600 RPM.
The only reason I chose to pick that apart, is for what it's worth it could be a significant clue to an unnoticed issue beit for You or for Me.
Thanks for the info man. And yeah we are probly on two different pages. Like i said im not much of a tranny guy (especially automatic transmissions), and obviously i have no clue and am asking for info haha. I will probly troubleshoot and start with the tourque converter and see what the part number is as Hey You suggested.
I am Not a tranny guy really either, I understand why you would be nervous....but keep in mind these things were designed by Dodge, not NASA.
Transmission shops make their money mostly in labor cost because rebuilding a tranny is not all that expensive to do, even starting with a total gut out of the case.
Doing the Math below will prove that much.......and anytime you see $1800 for an OEM REMAN, that is without a freight calculation which will rapidly double or triple total cost.
1. a 46RE/47RE/A518 rebuild kit with raybestos clutches comprised of fresh metal and frictions both [every one you will need, including about 4 you won't] as well as every filter and seal you need ( and obviously a dozen you won't) can run you for $150 or less
2. the Gov pressure sensor switch and transducer (MOPAR OEM) can run you for $80 or More
3. OEM recommended replacement stall speed torque converter can run you for $200 or less
4. a new AT Pan (mine was rusted to hell) can run you for $ 45 or less, but more if going to the drain plug type
5. **New upper and Lower cooler lines can run you for $50 or less
6. **New brass cooler line fittings can run you for $80 or less
7. then the cost of enough ATF to fill 'er back up, which is 2 gallons varies widely (you don't use all of the 2nd gal)
**items I needed due to heavy presence of thread lock compound, I was forced to cut the lines and later destroy the brass extracting them from the case.
Old Apr 2, 2016 | 09:12 AM
frankie_b_jr's Avatar
frankie_b_jr
750 idle on an automatic is stock, 600 for a manual... at least for a 97. I don't know if they changed that on any other years.
When I did my cab and trans swap I ordered a canned tune from Hemifever with the trans delete. At 600 rpm I couldn't do anything at idle, it wouldn't even try to charge. Since we were having issues with the tune throwing a few un readable codes I had Sean bump the idle back up to 750 and it made a world of difference. When this 408 goes in I'm going to try to get my Idle at 800 for charging and pulling at idle through the hills.
Old Apr 2, 2016 | 02:05 PM
Double Oh Dodge
I dunno either, ole girl is stock as all hell, 2000 5.9 auto. I doubt tow pack would make it idle as a stick......I just know what my dials are saying. Additionally She ain't got a single issue with bolting up to 5 mph if dropped in gear and let go on a flat stretch.
