Front Axle Pinion Flange - Need Specs!
Old Aug 4, 2016 | 11:30 AM
Cruzer555's Avatar
Cruzer555
Default Front Axle Pinion Flange - Need Specs!
I broke off one of the front driveshaft bolts into the flange on the front axle.
Need to know what the specs are. I know it's a Dana 44 axle but it seems like they sell 26 and 29 spline versions.
Thanks
Old Aug 4, 2016 | 11:36 AM
Friar Tuck's Avatar
Friar Tuck
Is this on your '99?
Old Aug 4, 2016 | 09:28 PM
Moparite's Avatar
Moparite
Do you mean the yoke? Get the bill of materials # then you can look up the part #
Old Aug 5, 2016 | 04:01 PM
Cruzer555's Avatar
Cruzer555
Yeah it's on the 1999 1500 with 3.55 gears.
And yes the yoke is what I need. The yoke that comes off the diff pinion for the front driveshaft to bolt to.
Not sure if I can read any numbers off the axle with all that rust!
Old Aug 5, 2016 | 05:09 PM
94Beater's Avatar
94Beater
Remove the old one and count the splines.
Front driveshaft uses 7290 u joints.
Look online for 7290 Dodge Yoke.
You should find one no problem
