Replace headlight knob
I"ve got a 2000 Ram sport. Need to replace the **** on the headlight switch. I was going to replace the whole switch unit, but it turns out I ordered the wrong switch. The one I need is WITH the fog lights, the one I ordered by mistake is for a truck without fog lights. Can I just replace the **** since that's the only issue? And if so, How does the **** come off the new switch? It doesn't seem to want to come off.
You should be able to just pull the **** off the new switch and swap them, but some are glued in to prevent that. Just look at your old **** and see if there is something else holding it before tearing the new switch apart. If it doesn't come off moderate force, then you'll be better off returning the wrong switch and getting the right one.
