2001 ram 5.2 valve cover breather
Old Nov 13, 2016 | 06:54 PM
davin622's Avatar
davin622
Default 2001 ram 5.2 valve cover breather
I have a 2001 ram with a 318 that is new to me, can somebody verify which side the valve cover breather and pcv valve are on. It has a cai spectre brand intake installed and the passenger side valve cover elbow is plugged into the intake tube. Is this correct? Thanks for help
Old Nov 13, 2016 | 07:55 PM
40intrepid's Avatar
40intrepid
Mine has the Breather on the right (passenger) side, and the PCV on the left.
Old Nov 13, 2016 | 08:15 PM
davin622's Avatar
davin622
So the breather on your passenger side connects to the air box? I'm getting a terrible air leak sound from this cold air intake. Everything is tight. Just making sure it's properly installed
Old Nov 13, 2016 | 10:34 PM
40intrepid's Avatar
40intrepid
Mine is all stock, and has the hose from the breather going to the airbox.
Is there a gasket between your cold air intake, and the throttle body?
Does the intake sit squarely on the throttle body?
Old Nov 14, 2016 | 05:37 AM
davin622's Avatar
davin622
I bought a new o-ring gasket for the throttle body, I will take it apart and see if it's not the problem
