Decent heads and cam for 5.9 rebuild?
Old Dec 30, 2016 | 07:35 PM
Adobedude's Avatar
Adobedude
Originally Posted by dbbd1
Never mind...
Killer post, great info.
Old Dec 30, 2016 | 07:43 PM
dbbd1's Avatar
dbbd1
I AM known for my wit and intelligence...
Old Jan 1, 2017 | 02:12 PM
Adobedude's Avatar
Adobedude
Me too!
Old Jan 3, 2017 | 02:56 PM
nicraage's Avatar
nicraage
Originally Posted by Hemibuck
Hey so I am trying to get as much info on the rebuild for my 5.9 before I pull the trigger on it in the spring. I have been told the stroker is the way to go but that unless I'm ready to dump a ton into it, the build will be crap. Others have said to just rebuild the stock block with a good set of heads, intake ,TB and cam. So that is what I am looking into now.
I did a mild set of heads and cam on my 5.7 Hemi and it was great. Can someone guide me in the direction of a decent set of ready to go heads and cam set up? I'm not looking into making a massive amount of power just a nice bump with the reliability that I have had with the stock set up. Thanks for the advice.
I bought some aftermarket heads a couple years ago from "Clearwater cylinder heads" also known as "Odessa Heads" They have both remanufactured and aftermarket. The aftermarket are beefed up in some weak areas. I've done some motor upgrades, and have not had any issues. What I can definitely day about them is they had very good customer service with me. They waved my core charge when they found out I was on a military base outside the US. I just looked on their website, but didn't see the heads for our motor, but it also says much of their stock is not listed.
Old Jan 4, 2017 | 10:13 AM
Hemibuck's Avatar
Hemibuck
Thanks for the info. I will look into them. I'm probably just going to go with a stock replacement head. The aftermarket ones flow better than stock and are stronger than stock. I was hoping to get a head that was in-between stock and the Monsters but it looks like that they don't make them. However I will ask these guys if they can make a set.
Old Jan 4, 2017 | 12:08 PM
frankie_b_jr's Avatar
frankie_b_jr
PF-CHR300N is the Clearwater/Odessa heads part number for the heads I got for my 408. They are better cast stock replacements with stock sized valves. They kind of fall between stock and monster EQs. You can check their eBay store for that number, or call them.
Old Jan 4, 2017 | 12:13 PM
Tboned's Avatar
Tboned
http://www.cylinder-heads.com/cylind...ce/fits-92-04/
Old Jan 4, 2017 | 05:34 PM
Hemibuck's Avatar
Hemibuck
Thanks will do!
Old Mar 16, 2017 | 11:05 AM
mr5racing's Avatar
mr5racing
i have a set of Magnum R/T 7140 heads that we dynoed and were just as good as the Indy heads with the M1 dual plane intake. its all about the match. we were using this combo to run circle track asphalt modifeds and rules changed. i dont have enough posts to list them for sale so forgive me for talking it up. ive listed them on most Mopar sites and Facebook mopar parts sites.
http://img159.imagevenue.com/img.php..._122_210lo.jpg
http://img141.imagevenue.com/img.php..._122_418lo.jpg
Old Mar 16, 2017 | 06:25 PM
44dakota's Avatar
44dakota
I think i can add to that a little, get that CAI off the top on put a good old fashion 10" or 14" round air filter on there with a K&N filter, you will also be pleasantly surprized...
