2001 Ram 1500 4wd
Old Jan 29, 2017 | 10:59 PM
lcinque707's Avatar
lcinque707
Default 2001 Ram 1500 4wd
Is there any way to grease the lower ball joints without pulling the axle shafts?
Old Jan 30, 2017 | 07:28 PM
Moparite's Avatar
Moparite
Are they stock? I don't think the stock ones have grease fitting holes. If they are not you should have a plug in the hole. You need to remove it and screw in 45-90* grease fitting. You need to position the u joint between the crosses to gain access. It's a PITA but that's how you do it.
