Rear main inside oil pan!?!?!?!
Old Feb 16, 2017 | 01:13 PM
rinowskib's Avatar
rinowskib
Default Rear main inside oil pan!?!?!?!
So I just bought a 2000 Dodge Ram 5.2l 4wd. Throw out bearing was out so bought an all new clutch kit to put in it. Full disclosure I am a diesel mechanic (work on semi trucks) but don't have a lot of experience on pickups. Anyways I had oil showing on the bottom between trans and engine. Valve covers and everything else are fine. I have the transmission out and the flywheel off. Now this is a little different than what I'm used to seeing. For one it's a two piece seal which is fine I get it. The thing that's troubling me is it looks like the rear main is INSIDE OF THE OIL PAN! If it's leaking wouldn't the leak be INSIDE THE PAN.???? It looks like I have to remove the rear bearing cap to do it, which I haven't done yet. Wondering if it's just the oil pan leaking at this point although it has all the signs of a rear main leak like what I usually see. What do I do????
Old Feb 16, 2017 | 01:59 PM
TNtech's Avatar
TNtech
Site Moderator-Dodge Tech
It's a 2 -piece lip seal that is in the main cap and block. Old school
Old Feb 16, 2017 | 07:15 PM
Moparite's Avatar
Moparite
This is what the block looks like with the cap off. Oil seal goes in the groove to the left.
The oil pump bolts to the rear cap.
Old Feb 17, 2017 | 11:12 AM
Ramman18's Avatar
Ramman18
Yes, pan comes off, rear cap comes off. Lots of little edges and creases to seal up and the seal itself is a pain to get right. Then you get it all together and pray is stops leaking.
Old Feb 17, 2017 | 02:16 PM
ram-tuff's Avatar
ram-tuff
I just did mine, it ain't hard. Plenty of instructions and videos out there showing examples of others doing it. Those really helped me get everything right the first time. That and the SM.
My thread with a few pics and comments on the job but there are others that are better as i'm just documenting my truck for history:
Post #8
https://dodgeforum.com/forum/2nd-gen...m-project.html
Old Feb 26, 2017 | 09:10 PM
rinowskib's Avatar
rinowskib
Thanks guys I got it no problem. Just never seen one like that before
Old Feb 27, 2017 | 12:36 PM
Ramman18's Avatar
Ramman18
Most people don't know about it. Even shops.
Before I did my own clutch and rear seal, I asked a shop to quote me and he said he'd throw in a new seal included with the clutch. I said are you sure? It's not a one piece and you have to drop the pan, etc. He said of course its one piece and right there after the clutch is pulled. I knew better so I walked.
