climate control too hot or too cold
Old Nov 18, 2005 | 03:09 PM
quedogf94's Avatar
quedogf94
Default climate control too hot or too cold
My climate control is not working properly its either too hot or too cold, no in between.
Old Nov 18, 2005 | 03:34 PM
hometheaterman's Avatar
hometheaterman
Default RE: climate control too hot or too cold
Did it used to work? It might be normal when I turn the heat on it gets really really hot. I can turn it down and have it not as hot though.
Old Nov 18, 2005 | 05:36 PM
quedogf94's Avatar
quedogf94
It used to work. I noticed one day there was a loud noise coming out the vent it sounded like there was some trash in the vents. I turned off the unit and turned it back on and haven't heard the noise again. If the unit is hot, I turn the **** to the left to the middle position to make it cooler, but hot air is still blowing from the vents. Cooler air does not come out until I turn the **** all the way to the left, then very cold air is coming out. Its either extreme hot or extreme cold.
Old Nov 18, 2005 | 08:46 PM
blasticblazin's Avatar
blasticblazin
ORIGINAL: quedogf94
i experienced the same problem....and now mine has gotten bad to the extreme that sometimes it only does what it wants....explained further in this post(https://dodgeforum.com/m_322068/mpag.../tm.htm#322068), but still not solved
