LED 3rd brake light won't turn off when truck is off
So I purchased a aftermarket LED 3rd brake light for my truck and when I went to plug it in and screw it own the light was on but my truck wasn't turned on ,so i was thinking ok maby my dim switch is on or my door is open . Sony turned both the dim switch off and closed the door and it still was on and won't turn off anyone know why it stays on when the truck is off and how can I fix that .
Truck info? What aftermarket light did you get?
Even if your truck is off, when you tap the brake pedal, the brake lights will light. Do your other brake lights come on too?
[QUOTE=Moparite;3349281]Truck info? What aftermarket light did you get?[/QUOTT
The truck is a 2001 Dodge Ram 1500 2 wyd with a 5.2 and no nun of the other brake lights stay on and the actual center light doesn't come on unless I hit the brake just the lights on the 3rd brake light |
So you're saying that it's the clear/white cargo lights that are on?
Originally Posted by dbbd1
(Post 3349312)
Off , I made shire all switches where off white / clear cargo lights still remain turned on at all times |
Turn the headlight switch, and they will turn off.
(Post 3349335)
Then you have something wired wrong.
Keep in mind, the headlight switch controls the ground for the cargo lamp. |
(Post 3349312)
| All times are GMT -4. The time now is 06:44 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
