what muffler came stock on 97 Ram SS/T?
Old Aug 1, 2017 | 08:14 AM
ramsportrocks's Avatar
ramsportrocks
Default what muffler came stock on 97 Ram SS/T?
as the title says I am looking for what muffler came STOCK on a 97 Ram SS/T
I don't want to run cat back duals.. want to have a high flow cat installed with a stock style exhaust system
thanks in advance
Old Aug 2, 2017 | 07:52 AM
ramsportrocks
read that it was a delta 40 flowmaster.. can anyone comfirm??
Old Aug 2, 2017 | 07:32 PM
Moparite's Avatar
Moparite
The SS/T's and Indy rams had the same one as every other ram(excluding HD, V10/diesel). Never heard other wise and why would the factory put on aftermarket mufflers?
Old Aug 2, 2017 | 08:28 PM
AtomicDog's Avatar
AtomicDog
For a stock style single exhaust system and a high flow cat, I went with a 3" single system from the cat back through the tailpipe. I picked up the following parts and took them to a local muffler shop for installation:
Dynomax UltraFlo Welded Muffler - 17233
Magnaflow Converter - 99047HM (dual 2" inlets, 3" outlet, front O2 sensor port)
3 - 3" band clamps (back of cat, front + rear of muffler)
1 - bung for rear O2 sensor
The muffler shop cut out the old cat and installed the new one and supplied the 3" pipe needed to complete the system and fabricate a tail pipe. I also supplied 2 new O2 sensors for the system. System works and sounds great.
Old Aug 3, 2017 | 10:52 AM
ramsportrocks
NEAP option on the build sheet is " sport tuned exhaust " that leads me to believe something other than a standard muffler used across the line was used on the indy's and ram SS/Ts..
I remember when they came out and they definitely had a throatier exhaust note to them over a stock ram 1500..
Old Aug 3, 2017 | 11:00 AM
Never heard of a manufacturer equipping vehicles with aftermarket mufflers.....
Old Aug 3, 2017 | 11:07 PM
itate's Avatar
itate
The 98 parts catalog shows they used Dynomax mufflers, part #52103146 for the SS/T.
Old Aug 4, 2017 | 10:48 AM
ramsportrocks
thank you, this is the info I was looking for
no longer made but I wrote to dynomax to see what they sell that is equivalent to this old part #
Old Aug 4, 2017 | 07:26 PM
itate's Avatar
itate
Cool, I'll be interested in what they say.
Old Aug 6, 2017 | 07:06 AM
ramsportrocks
still no response back from them.. I will try again tomorrow
