Transmission issue
Old Aug 5, 2017 | 07:05 AM
dkf1979's Avatar
dkf1979
Default Transmission issue
My son has a 97 Ram 1500 2wd with a 5.2L 318. I had to have him towed home due to his transmission going out. Or so i thought. If i let the truck sit over night, when you start the truck it will go right into drive, or reverse and work perfectly. But after about 5 minutes, you lose everything on the transmission. It won't do a thing in any gear you select. Any ideas? Seems to me if the transmission was truly shot, it would slip all the time.
Old Aug 5, 2017 | 07:31 AM
Moparite's Avatar
Moparite
It may be pump related, When was the filter changed last? What does the fluid look/smell like? Might do a pressure test to see what's going on.
http://www.atraonline.com/manuals/se...0/2000_154.pdf
Old Aug 5, 2017 | 07:39 AM
dkf1979's Avatar
dkf1979
Thanks for the reply. He's only had the truck for about 6 months so i don't know a lot about the history. There's a sticker under the hood that says the transmission was serviced about 40,000 miles ago.
I should also say that it's throwing the P0740 code (a/t torque converter clutch).
The fluid looks great, but it did smell a bit burnt.
