Leveling kit
Old Sep 9, 2017 | 07:55 PM
John Zuppan's Avatar
John Zuppan
New Member
Default Leveling kit
Just installed a 3inch front lift to level my truck. Getting new shocks, Do I need 4 new shocks? 02 dodge ram 2500 4wd
Old Sep 9, 2017 | 08:28 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
No just the fronts, if that.
Old Sep 10, 2017 | 05:46 PM
Ramman18's Avatar
Ramman18
Just the fronts will need to be replaced with longer units for up to 3" lift. If you don't, they will top out on bumps and either blow or give you terrible clunks.
The rears can handle quite a bit of lift. IIRC my rears are stock to 5" or something like that.
What you WILL want to get is an adjustable track bar to re-center the axle. Just slapping in a "level" kit is not good enough. Take a look at actual 3" lift kits and you'll see all the parts you should get to do it right. But it's an old truck, so who cares?
Old Sep 10, 2017 | 11:37 PM
John Zuppan
New Member
Called rough country and they suggested these. What do you think
