00 1500 can rad drain seal be replaced
Old Sep 15, 2017 | 02:54 PM
comet424's Avatar
comet424
Default 00 1500 can rad drain seal be replaced
Hi i recently had to get my rad repaired
drained it and took it and had fixed but after installed and running noticed the drain plug leaking out of the drsin pipe
Tried turning open closed couple times fixd it for a bit but leaking again
Can thr sesl be replaced does that turn **** pop out i guessing its o ring in there
Old Sep 15, 2017 | 07:46 PM
AtomicDog's Avatar
AtomicDog
Yes, it can be fixed. I believe there is a rubber washer that helps to seal the petcock to the radiator. You should be able to find one on the HELP parts aisle at your local auto parts store.
Old Sep 17, 2017 | 09:58 AM
comet424's Avatar
comet424
ah ok ill check it out
so to get it out i dont wanna pull the rad back out.. i twist the **** to let the fluid drain out do i grab pliers to pull out the **** or does it turn out more to pop out or a special lock that holds them in?
Old Sep 17, 2017 | 12:08 PM
AtomicDog's Avatar
AtomicDog
Yes, you should be able to just turn the **** until it comes out of the radiator. Some may have a piece of nylon to help keep the petcock with the radiator, but I typically tug on the petcock and it will come out. No need to remove the radiator to remove the petcock.
Old Sep 17, 2017 | 01:03 PM
comet424's Avatar
comet424
awesome ill try it tommorow and is it just an o ring or nylon thing.. is it called a rad o ring seal or so when i goto canadian tire
Old Sep 17, 2017 | 11:14 PM
AtomicDog's Avatar
AtomicDog
Should be a rubber washer that fits around the threads of the petcock.
