Front end suspension
Old Dec 11, 2017 | 11:50 PM
Rammit82's Avatar
Rammit82
Default Front end suspension
Would u be able to change out the control arms with the truck on the ground or would it be easier to do the job with the truck on a lift
Old Dec 12, 2017 | 09:07 AM
AtomicDog's Avatar
AtomicDog
The job would be easiest when done on a lift. You will not be able to do the job without at least jacking up each side to relieve pressure/weight off the control arm to remove it.
Old Dec 12, 2017 | 09:09 AM
primem's Avatar
primem
if its control arms from an independent front suspension...up in the air
if its trailing arms from a coil and link suspension...probably on the ground. have not had to do one though.
Old Dec 13, 2017 | 12:06 AM
Ramman18's Avatar
Ramman18
Any job is best on a lift if you have one.
When I did my CAs, I jacked up the frame behind the mounts and let the axle sag. I also did lift coils.
