Engine Toast??
Old Jan 11, 2018 | 02:00 PM
chuckmccall's Avatar
chuckmccall
Default Engine Toast??
I recently bought a 1998 Dodge Ram 1500 2WD with the 3.9L V6 engine. It has 153,000 miles. Test drive and visual inspection were good - no problem detected. After I bought it, I changed the engine oil (10W30 Castrol). There were no problems during the first few weeks. Then last weekend, I was driving normally on the highway. The power started dropping. First I could only get up to 40 MPH, then 30, then 20. Finally, after about 10 miles, the engine completely shut down. The engine would turn over but not start. I had the truck towed to the local Dodge dealership service department. They checked the diagnostic codes and said it was showing faulty distributor and/or plug wires. They replaced those and it still won't start. They've had it 4 days now trying to find the problem. They called today and said the engine is dead, no compression, must be replaced. I'm having a hard time believing that the engine is shot. I had not noticed any oil leakage or usage during the 3 weeks I've been driving it. I really expected the problem to be the fuel pump or fuel filter. Anyone have any thoughts on a next step? Thanks
Old Jan 11, 2018 | 02:28 PM
Get a second opinion if you don't like theirs. It's a 20 year old engine.
Old Jan 11, 2018 | 03:37 PM
AtomicDog's Avatar
AtomicDog
Did you take it back to where you bought it from for this repair? Even though the vehicle was used, there still may be some sort of warranty/lemon law applicable for your area/state.
Old Jan 11, 2018 | 03:55 PM
chuckmccall
I bought the truck from a small local car lot as is/no warranty. I honestly don't think the guy knew there was a problem with the engine. He disclosed a lot of minor issues but nothing related to the engine.
We talked to the service department manager again. He says the cylinders are showing 60%, 0%, 30%, 40%, 0%, 0%. I guess that makes it pretty obvious the engine is history.
Old Jan 11, 2018 | 05:00 PM
AtomicDog's Avatar
AtomicDog
I just purchased a small car (2001 Nissan Sentra GXE 1.8) from a shop that had told the original owner that the car "had a blown head gasket". The original decided to sell the car on craigslist. I went to look at the car and noticed that the shop had pulled the plugs and coil packs and left them sitting out. I came back and did a quick compression check and noticed that cylinder #1 was down just a bit on compression and all the other cylinders were fine, so I decided to purchase the car. Once I had the car towed to my house, I cleaned the plugs, re-installed the plugs and coil packs on the motor and fired it up. The motor instantly fired up and ran like a Swiss watch. I've been driving the car and have not experienced it run hot or show signs of a blown head gasket.
I say all of this to say that its likely best to get a second opinion from a trusted source. Personally, I would have taken the vehicle back to where you bought it from to see what they could do for you.
