Hi Beams with light bar
Old May 18, 2018 | 09:56 AM
V65Ozzie's Avatar
V65Ozzie
The headlight switch may not be happy with an additional load..... so, using relays is going to be the hot ticket. If the switch provides ground path for the circuit, simply tap into it, and use it as the ground for the relay control circuit, and have the relay provide power to the lights.
+1 Definately the way to go. But....run a kill circuit, because, y'know, police.....
"My fog lights were on? Weird, let me check.......hmmmmm? they are off now, I must have a short somewhere officer. Thanks for bringing it to my attention. Let me pull a fuse to disable that circuit and I'll fix it when I get home(fumble around in fuse box) You know how these old dodges are, finicky wiring........."
Not that I would ever do something like that.........
Old Jan 26, 2023 | 07:14 PM
Big_Willie_01_2500's Avatar
Big_Willie_01_2500
Originally Posted by WR_Dave
Hi Sherrif420,thanks for the info.
I tried that way originally and due to the headlight wires all having 12.6 volts on them with the lights off, the grounding wire at 86 that you mentioned will keep the light bar on when the truck or the lights are turned off.
Again, I am not 100% sure that I am still fighting a DRL issue as well, which may be giving me a bunch of false results.
Did you every solve this problem I am wanting to do the same thing
Thanks
Old Jan 26, 2023 | 07:17 PM
Big_Willie_01_2500
Originally Posted by Sheriff420
I just went and looked. The bumper lights (55 watt x 2) are connected to a headlight harness and plugged into the driver side because I have one of the LMC harnesses running my headlights and it's plugged into the passenger side. So my ground for the bumper lights is coming from the driver headlight plug since the headlight switch only runs the bumper lights and two relays for the headlights.
So it's wired like I said before with the only difference being that the ground is the ground on the headlight plug.
If you're going to run the 100/80 watt bulbs like I am then you'll want to think about getting the LMC headlight harness because the higher wattage bulbs along with whatever the light bar is pulling will cook a headlight switch pretty quick.
FYI - The higher wattage bulbs are worth it. They're labeled as offroad bulbs by Hella but they don't blind people like all the people running LED lights in stock housings so I don't pay any attention to the off road only rating. My 2015 Mustang with HID lights aren't as bright as the lights on my truck.
Sheriff could explain exactly how you got yours to work like I am 5 years old and dumb? I have this light kit
Amazon.com: Nilight 12 Inch 72W Led Light Bar Spot Flood Combo 2PCS 4 Inch 18W Led Pods Flood Boat Lights Driving Fog Lights Work Light for Trucks with Off Road Wiring Harness- 3 Leads, 2 Years Warranty : Automotive Amazon.com: Nilight 12 Inch 72W Led Light Bar Spot Flood Combo 2PCS 4 Inch 18W Led Pods Flood Boat Lights Driving Fog Lights Work Light for Trucks with Off Road Wiring Harness- 3 Leads, 2 Years Warranty : Automotive
And when I am done I wanted to be wired like this guy did his which sounds like how you have yours
Thanks!
