Clear Fluid Leak
Old May 20, 2018 | 10:33 PM
Willard90's Avatar
Willard90
Default Clear Fluid Leak
2014 Dodge Ram 2500 Cummins Turbo Diesel.
I recently noticed a leak under my truck. The fluid appeared to be clear so and first i assumed it was condensation from the AC, ( it was a hot day and I had been running the AC full blast for quite some time) but the next day i noticed the puddle hadn't evaporated. The fluid had a slight odor but not much color. The next day the check engine light came on when I started it up. I checked under the hood and noticed a pink fluid all over the Ram Active Air cap. I did a cold check of the tranny fluid and it appears to be full. Any ideas what I'm dealing with?
Old May 20, 2018 | 11:12 PM
2bit's Avatar
2bit
DEF? You're in the wrong section, this is 94-02 Rams.
