46RE to NV4500
Old Jul 9, 2018 | 03:49 AM
HeikIlm's Avatar
HeikIlm
I'm talking neutral safety switch. So cut my safety switch off (3 prong) and wire in the manual 2 prong plug
Cut off the 3 prong connector, and connect outer wires to the back-up light switch. Violet w/black tracer goes to the back-up lights, brown w/light green tracer is hot, comes from the fuse block (black w/yellow tracer I was talking earlier, is a tail light wire).
Middle wire is the neutral safety, black w/white tracer, and is grounded by the switch. So you need to wire it to the clutch switch to be able to start the engine.
Those wire colors are from 1995 diagram, so verify them before cutting.
Old Jul 9, 2018 | 12:39 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Thanks for that info!
