2000 ram 1500 vacuum check valves. help
Old Aug 8, 2018 | 07:45 PM
donnieb's Avatar
donnieb
Default 2000 ram 1500 vacuum check valves. help
where can i find new check valves for my truck. what numbers can i give the dealer. they can't find the valve
Old Aug 8, 2018 | 07:49 PM
Ramman18's Avatar
Ramman18
Avoid dealer. Amazon has them:
https://www.amazon.com/ACDelco-14047619-Original-Equipment-Control/dp/B000C982H2
Old Aug 8, 2018 | 09:47 PM
donnieb's Avatar
donnieb
thanks for your help. i will go online to check on them.
Old Aug 9, 2018 | 06:39 AM
Moparite's Avatar
Moparite
You can get them at your local napa.
https://www.napaonline.com/en/p/NDP7301349
Old Aug 9, 2018 | 12:16 PM
Ramman18's Avatar
Ramman18
Napa carries Dorman chinese junk. I know. Used them for years. Then I found the OEM AC Delco part that is shared with GM on Amazon. Much better part! I had bad vents (for the umteenth time) with the Napa valves and both passed the "blow/suck" test. Replaced with AC Delco parts and everything worked.
Old Aug 11, 2018 | 12:40 AM
donnieb's Avatar
donnieb
thanks again guys. going to order parts
