p0601 no start when hot
Old Sep 15, 2018 | 10:15 PM
ram6767's Avatar
ram6767
Default p0601 no start when hot
I have a 2001 dodge ram 2500 5.9 gas and it starts up fine and drives and starts short distance fine under 5 mins. If I drive over 5 mins and shut it off it wont start for atleast 2-3 hours it just cranks. Then soon as it is cooled down fires up like no problem. I do have a code for p0601 something to do with ecm, do I need a new computer to fix this? Can I have ecm thats in truck reflashed? also replaced crank sensor
Old Sep 16, 2018 | 08:06 AM
Moparite's Avatar
Moparite
P0601 PCM Internal Controller Failure
Old Sep 16, 2018 | 09:44 AM
ram6767's Avatar
ram6767
so needs a pcm
Old Sep 16, 2018 | 11:09 PM
fj5gtx's Avatar
fj5gtx
I replaced the one on my 04, because it was adamant the front o2 sensor wasn't working - and I couldn't pass inspection with the warning light on.
If the 2nd gens are like the 3rd gens, there is a sticker on it with numbers - you want to match the numbers, then have someone flash it to your configuration. I bought mine from ebay for like $40 shipped, then had the dealer program it for $75. Or you could ship it off to be repaired and flashed to your configuration for a bit more.
