Electrical, Lights
Guy stopped by to tell me my lights were on, great thanks -- however when I went out to truck (1996 2500 3/4 4WD Cummins) I had no tail lights. Found the 15A fuse blown, # 18, and replaced fuse -- turned on lights and fuse blew again.
I pulled the light switch and went direct to the wire for the tail light , license plate light and rear parking lights, and fuse blew. Thus seems not a switch issue. Next, disconnected the tail lights, license plate lights and hitch lights -- all disconnects at plugs completely removing these items from the circuit. Circuit still blows fuse. Now, in process of disconnecting front lights will see if this helps. Any suggestions?? |
Have a trailer harness on that? If so, check where the trailer harness meets the rear harness.
HeyYou, thanks for the info as it got me thinking. First off I did disconnect the rear bumper trailer plug, however forgot I have a forward bed plug for a slide in camper. This forward plug looks like a professional installation so not sure if was factory or not. -- thus I am reluctant to cut into the wire run at this time.
I did go to the trailer relay in the power distribution center and pulled the relay and all my lights worked OK. Great!! Put the switch back in and turned on the light and the fuse popped. Although I did disconnect the lights/trailer plug in the rear of truck now appears it is in the forward portion or the switch wiring as this is what I moved putting switch back in. HELP Needed on this question -- where can I find a listing of the connectors and splices as to LOCATION in the truck. The manual give a list, but only component feed, but nothing on physical location. Thanks |
Originally Posted by Cartalk2
(Post 3412027)
MoparFanatic21 Thanks for reply. I have the hard copy of manual and just missed that section, it was there as you indicated. Thanks again.
(Post 3412166)
I was preparing to start separating connector in the front/cab of truck, but thought about the great wiring that is in these trucks. These wire system do not generally give problems unless damaged or altered. I had to look at the alterations I had made and the only one that seemed fit into running lights/panel lights was the retro-fit radio. I removed the radio and looks like problem solved. I can only guess where I lost all panel lights on the rheostat the problem is in the radio. What ever, my running lights seem back to normal -- I hope.
Surprising how many side circuits/splices are on this # 18 fuse, sure would be easer if it was dedicated to lighting. Thanks to all that replied. |
