Cummins conversion
Old Oct 11, 2018 | 02:01 PM
Ctyby1911's Avatar
Ctyby1911
Default Cummins conversion
Hey all, I'm sure this topic has been covered, but I have some questions. I want to swap out the gutless 5.9 gas and throw a Cummins into it. I have a 96 2500, HD version, old municipal truck. It has a 60 front end and a 70 rear. I know about having to either swap out or clean the fuel tank, new lines etc. My question is how hard/time consuming is it yo make the Cummins work in the truck? What else has to be done and changed?
Old Oct 11, 2018 | 02:07 PM
Here's an existing thread with some good info.
https://dodgeforum.com/forum/2nd-gen...el-1500-a.html
Old Oct 11, 2018 | 03:47 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
I went from a Cummins to a gasser (could like buying lift pumps). All in all it's not hard if you have everything. You would need the computer and harness if a 24V, engine mounts, transmission and that's about it that I can think of at the moment. If you are really picky the correct gauge cluster that says "Diesel Only."
