1996 ram 1500 rear end swap with a 2000-2001
Old Sep 24, 2024 | 11:18 PM
Black Beauty 2000 1500 5.2l 4x4's Avatar
Originally Posted by Keith_L
Don't touch the pinion nut. Get the correct u-joint or companion flange. Lengths will otherwise work, no need to change d/s length
I was just curious because mine is dented and I found one in my local salvage yard that's older it's a 96 mine is a 2000 same length cab same length bed both 4x4s same rear it just has the old school pinion flange with the clamps my 2000 has the companion flange I was just basically just wondering if they were the same otherwise length thanks I really appreciate it I was just curious before I went through all the hassle of hauling a big 3-ton floor jack through the yard to pull it!
