jtarrington |
01-08-2019 10:13 PM |
Still no spark, any suggestions?
So I posted awhile back about an issue that was somewhat similar which ended up being the PCM. I have a 98 1500. The other day while I was driving the truck it would flutter losing power is the only way I know to explain it. It was lose power and come back almost like a light switch every now and then. Until it just didn’t come back. It lost power and when dead so while still coasting I dropped to neutral and started back up just for it to lose power again and never start back up. It will turn over but not start.
I cannot figure out why I still don’t have spark. After part chasing the problem I don’t know where else to check. I’ve replaced ignition coil, distributor cap, distributor rotor, pickup coil, crankshaft position sensor , and checked fuses and relays. I would be likely to think it was the pcm since this very similar to what I’ve already dealt with but I have another one that I know the truck will start with and swapped it with the same result. Any suggestions?
