**Need Help** 24 Valve Knocking Noise
Old Feb 3, 2019 | 02:25 PM
Meximelt3500's Avatar
Meximelt3500
Originally Posted by HeikIlm
Damn, that sounds nasty! Remove that rubber coupling from the intake horn, and check if the noise actually comes from the intake side.
Definitely not a motor mount.
I took the coupling off at that joint and it definitely is coming from that area
Old Feb 4, 2019 | 01:11 AM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
You are going to have to try and figure out which area it's coming from.
