2001 Ram 1500 Instrument Cluster Lights
Old Feb 9, 2019 | 12:31 AM
100LL's Avatar
100LL
Default 2001 Ram 1500 Instrument Cluster Lights
The gauge cluster lighting on my new 2001 Ram 1500 hasn't worked since I got it. I replaced the ILLUM fuse but it blows immediately. I removed all of the ILLUM bulbs from the gauge cluster and the fuse doesn't blow. So I want to try replacing all 5 bulbs. It looks like they come out of the quarter-turn socket thingy, but I can't get them to come out. Nor can I find a part number for either the socket, bulb, or assembly, if it is an assembly. Help please!
Old Feb 9, 2019 | 12:32 AM
100LL's Avatar
100LL
Old Feb 9, 2019 | 01:59 AM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Originally Posted by 100LL
They come out but most likely will break. I used needle nose plies and wiggled then back and forth. Look for a number on the bulb if you can, three are 3 different sizes and if I ever right those are 94 bulbs. Just search eBay and you will find them. I can even get them from a junkyard if you want. I changed mine too purple leds
