426 Stroker
Old Feb 15, 2019 | 02:49 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Originally Posted by Gary Benoit
I'm not doing this for top end, this is for my truck and I'm going for more bottom end torque than anything else which is why the longer stroke, I do like the Mopar setup but will need to get bigger injectors to support it however depending on which way my finances go I may go with the 408 but needless to say and I still have to deal with the PCM as it is different than non PCM, I understand and respect all replies, comments and advises that you all have and it will help me with decisions on which way I will go. I am dealing with Hughes Engines and also going to check out a few places the do PCM programming and see what my options are
Hopefully Hughes didn't screw you like they did everyone else.
Old Feb 15, 2019 | 04:28 PM
dapepper9's Avatar
dapepper9
If you convert to obd2, avoid hughes for tuning. They go through PIE and you could probably blind tune a carb better
Old Feb 15, 2019 | 06:11 PM
Gary Benoit's Avatar
Gary Benoit
I have only read good reviews from them
Old Feb 15, 2019 | 06:44 PM
MoparFanatic21
When I was looking at parts for my engine build I found some pretty bad reviews which made me stay away. I'm not saying they are bad just I don't want to take a chance lol
Old Feb 18, 2023 | 01:37 PM
Wook's Avatar
Wook
Hi I have a 1995 Dodge Ram 1500 4x4 and I'm going to be rebuilding my 5.9L Magnum 360 into a 426 Stroker and would like to know if there is a PCM mod for this or would the stock PCM accept the motor just fine. I know 96 and up being OBD2 have flash mods for it however this is a 95 and OBD1
What all did you have to do when you put in the stroker kit? What cams and heads did you run? Bc I thought about buying the Hughes 426 stoker for my Dakota rt and continually using it as a daily after I rebuild it this summer
Old Feb 18, 2023 | 02:09 PM
staycool72's Avatar
staycool72
I ended up doing a 408 Stroker instead due to the fact that the 426 Stroker is for race only and there is a lot that would need to go into it and would not be suitable for daily use, I put the EdelBrock Performer RPM Heads on, The Cam and Lifter set I got from Competition Cams 221/225 @.50 Duration .507/.533 Lift, T-Bar Lifters, the Stroker Kit was put in at the Machine Shop when they did the block, I got the Stroker kit from Hughes, almost finished assembling the motor as it took a long time at the Machine Shop
Old Mar 2, 2023 | 01:28 PM
mharrington's Avatar
mharrington
New member here saying hello. So I too am contemplating the 426 stroker kit because its flat out cool. My pro street Dakota 1995 will have a tunnel ram and 2 Edelbrock carbs. Im gonna mildly port and polish some new Chinese EQ heads with the LA intake bolt pattern. I realize the 426 stroker is not recommended for nitrous which is a little bummer. The BluePrint 408 assembled shortblock would be fine for me. What are members with 1995 era 2wd Dakotas using for an extra capacity oil pan and windage tray for stroker magnums?
