running rich
Old Feb 21, 2019 | 01:29 PM
miker111's Avatar
miker111
may be that 400,000
its just going to be that way
its been a great truck
thanks
Old Feb 21, 2019 | 01:45 PM
99DR's Avatar
99DR
It might. But it might still give a signal that reads -40 degrees. It's simple enough to test both without looking at live data feed. Disconnect the purge valve to manifold connection and plug the vacuum leak to the intake. See if the issue goes away. If it does, either the Intake temperature sensor is sending a bad reading, or the Purge Valve Solenoid is stuck.
Originally Posted by miker111
would not air temp sensor or purge sole cause cel
may be injectors but the truck runs good
like i said it gets driven 100 miles a day
thanks
Old Feb 21, 2019 | 01:50 PM
racefan41's Avatar
racefan41
Injector cleaners like Tekron or Lucas through your tank work good.
miker111's Avatar
miker111
ok
i will check this out this afternoon
thanks a lot
mike
Old Feb 21, 2019 | 01:53 PM
miker111's Avatar
miker111
i have put cleaner in
but i dont let it get below 1/2 tank
so i fill it up every two days at the same station
not that with age inj get weak
thanks
mike
Old Feb 21, 2019 | 02:33 PM
99DR's Avatar
99DR
You don't happen to have a scanner that can display Live Data, do you? If so, would you mind checking the Long Term ADAP and Short Term ADAP (Dodge speak for Fuel Trim)...also the 02 Sensor voltage (it should be oscillating.)
ok
thanks a lot
mike
Old Feb 21, 2019 | 03:02 PM
miker111's Avatar
miker111
ok
long running -2.3
short running 6.3 to 10.9
02 b1 0.120 to 0.960
b2 or rear 0.120- 0.140
cheap scan tool
thanks mike
Old Feb 21, 2019 | 03:28 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
ok
long running -2.3
cheap scan tool
thanks mike
To me it seems like your fuel trims are off. They are suppose to zero out each other or at least really close
Old Feb 21, 2019 | 04:01 PM
99DR's Avatar
99DR
OK. Is the engine warm? Your fuel trims should be closer to zero, BUT 6.3-10.9 isn't terrible. It just means that the STFT is trying to compensate for a lean condition. The LTFT will eventually catch up to the SHFT. LTFT is almost like a longer term running average. And I'll assume that is at idle? See what happens to the fuel trims when you push the gas pedal down. See if the SHTF goes below the LTFT...or at least goes near it. If it does, there is most certainly unmetered air getting into the system, and causing the O2 sensor to richen the system. When you press the gas pedal down, the small vacuum leak will be a much lower ratio to total air, and the STFT will go down.
If STFT doesn't go to 0, or close to it, when you mash the pedal, definitely check the purge valve as I detailed earlier.
ok
long running -2.3
cheap scan tool
thanks mike
Old Feb 21, 2019 | 04:05 PM
99DR's Avatar
99DR
You're correct. 0 is the baseline. A positive value means that the ECM is trying to richen the mixture, by xx% So, in this case, nearly 10%. If it's a negative number, it's trying to reduce fuel/air mixture by xx%. Some older cars will not change the LTFT until the mixture has reached 14.7:1. It waits for the mixture to reach that ratio, then moves it back to the new baseline.
ok
long running -2.3
cheap scan tool
thanks mike
