Abs helpA for 98 ram
Old Mar 27, 2019 | 02:20 PM
Stuart Holmes's Avatar
Stuart Holmes
Default Abs helpA for 98 ram
I have a 1998 dodge ram 1500 4x4 with the abs and brake lights on. Last time it did this (about 5 years ago) it was the sensor on the rear differential. Is there any way to get the codes? Want to see if it's the same sensor or on of the front ones.
Old Mar 27, 2019 | 02:51 PM
99DR's Avatar
99DR
I'm not sure if you can on a cheap scan tool. I can with both my Autel 802 and MS906BT. The 802 is reasonably priced, but not a budget tool. Maybe the auto parts store has a tool that scans all of your systems?
Old Mar 27, 2019 | 05:45 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Ground pin 13 of the OBDll connector then it will flash
