Fuel pump
Old May 1, 2019 | 02:29 PM
Jason Parks's Avatar
Jason Parks
Default Fuel pump
I just replaced the fuel pump on my 1994 ram with a 5.9 the motor is turning over but will not fire, can anyone help me?
Old May 1, 2019 | 04:39 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Check to see if you are getting power to the Fuel Pump Relay
Old May 8, 2019 | 01:10 PM
Jason Parks
Default Fuel pump
I put a new relay in and I'm still not getting fuel to the rail
Old May 8, 2019 | 04:03 PM
HeikIlm's Avatar
HeikIlm
New relay is worthless if there is no power to the relay. Key in run position, check with test light or multimeter that you have power on pin 30. If not, check the fuse. If you have power, you can jump the pins 30 and 87 to see if the pump actually works. If yes, then you have problem in a circuit that activates the relay.
