NO BUS diagnostic
Old May 19, 2019 | 03:17 PM
JC2000's Avatar
JC2000
Default NO BUS diagnostic
Hey friends, does anyone have a solid step-by-step method of diagnosing a "no bus" code?
In my particular case (2000 5.9L) the ASD relay is buzzing and if I remove it, my fuel pump relay buzzes.
I'm getting full voltage on my 5v reference circuit at my TPS but I'm finding around 2.5 V on my injectors' 12v power feed.
Fuel pump doesn't prime but the starter works when I attempt to start.
I have the electrical diagram and am preparing to go to work, but just wondering if anyone has a good trick on where to begin and move forward.
Thanks!
Old May 19, 2019 | 03:23 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Thanks!
No bus means any of the wires going to the PCM could be bad
Old May 20, 2019 | 06:44 AM
Moparite's Avatar
Moparite
AKA a communication issue with the pcm. Do a search here for "no buss" there are a ton of threads on it.
