Engine Stalls
Old May 28, 2019 | 11:25 AM
JamesHretiredusaf's Avatar
JamesHretiredusaf
Default Engine Stalls
I have a 2001 Dodge Ram 2500 Cummings Diesel Truck. Engine Idles fine, Runs fine in Reverse, Idles fine inn Neutral, but stalls 3 seconds after being placed in Drive. Any suggestions as to the issue? Thanks all.
Old May 28, 2019 | 01:38 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Replace the Cummins with a gasser lol all joking aside, do you feel anything? Does it die slowly or quickly?
Old May 28, 2019 | 06:13 PM
JamesHretiredusaf
The engine stops as though I turned the key off. No unusual noises or operation.
Old May 28, 2019 | 08:16 PM
MoparFanatic21
Your need to make sure you have pressure at the lift pump when it stalls
